-   -   gen 6 454 pistons in a mark 4 454 block and more Q's?? (https://www.racingjunk.com/forums/showthread.php?t=19207)
jessejames79 12-15-2007 06:40 AM
i bought a set of gen 6 ho454 pistons 8.75:1 comp. and i'm just wondering if they'll work in a mark 4 block??? also anyone know how much lift they can take before fly-cutting the reliefs??? the cams i'm thinking of are doug herbert .685-.683 lift or crane .714-.714 lift blower cams and a set of canfield 350 heads any input on this combo will be apretiated i will be running an 871 blower on top... thanks again, Jim
lanham 12-16-2007 02:23 PM
pistons
The pistons will work as long as the rod length and deck height is the same.
