-   -   offset pinion (https://www.racingjunk.com/forums/showthread.php?t=19253)
olds48 12-19-2007 01:35 PM
offset pinion
Hey guys,first time on here for me.I got a?I'm tubbing my car and my buddy has a 9" housing,already narrowed,that will fit my car.Pure luck,this housing is about 10 years old :D Anyway,it has equal lentgth tubes and a centered hog head,which puts the pinion about 1.5" off-center of my car.Will this work?Will it eat u-joints?Will it bust my tailhousing?HOW DO I GET MY PIC TO THE LEFT OF THIS RAMBLIN' :? Any info will help please
olds48 12-19-2007 02:11 PM
Thanks George.Didn't realize there were different sections.Kinda new.Thanks :oops:
olds48 12-20-2007 07:27 PM
48 views and no replies.Help me out.Any info/opinion appreciated
spib 12-20-2007 07:41 PM
I heard pros and cons to both sides, I had my mopar 8 3/4 narrowed and both axels I decided to have same lenth which puts pinion , center off to right side some, but heard it wasnt a big deal , at least for what I want to do with it. No problems
edvancedengines 12-21-2007 02:23 AM
doesn't matter as long as it is not an extreme angle. The axles will be different lengths too.
Ed
lively 12-21-2007 04:48 AM
Ed
SAME HERE------LIVELY
jmarksdragster 12-21-2007 10:28 AM
Typically the rear housing is cut to center the pinion and two different axle lengths are used. Been a while since I cut one but I think it was around a 2" difference. If it were mine, I would cut it to center it. The other option is to use the Strange 12 Bolt center section, if you have to buy one anyway.It may be OK offset, but if this is a race only car it's better to get everything lined up.
lively 12-21-2007 02:17 PM
ALSO I FORGOT TO SAY[A.G.E. DISEASE :? ]---MAKE SURE THE CENTER OF TRANS / ENGINE COMBO AND THE REAREND PINION ARE RUNNING PARRALLEL TO EACH OTHER!!!--SORRY I DID NOT LET YOU KNOW EARLIER :shock: :shock: ---LIVELY
olds48 12-21-2007 04:02 PM
Best I can tell it's only about 1" offset to pass. side.My driveshaft is 52"center-center.So it shouldn't be alot of angle.Didn't know about the 12 center section,have to do some research.Thanks guys.Any other ideas?
edvancedengines 12-22-2007 04:44 AM
A flex-coupling (U-Joint) sees an angle. It doesn't care if the angle is to the right, the left, to the top, the bottom, or somewhere in-between. All the coupling knows is that it is there to flex becuase of an angle. Like I said forget it and run it. Just watch the up and down angles.
Ed
