-   -   Carb Size - BBC (https://www.racingjunk.com/forums/showthread.php?t=19303)
JLSTOEC 12-26-2007 10:55 AM
Carb Size - BBC
Im wondering what carb you guys think would work best for my combo listed below. Im assuming a Dominator, but what size, company? Thanks for the help.
1970 Chevelle
Drag Race Only
3200 Pounds with driver
29.5 x 11.5W Hoosier slicks
Southside Machine lower control arms and adjustable upper control arms
4.11 gears in 12 bolt Spool
Turbo 400 Trans with Transbrake
540 CI Big Block 4.50” Bore 4.25” Stroke
12.8:1 Compression
Bullet Roller Cam 4/7 swap. 276, 280 duration at .050. .757 .737 gross valve lift
AFR 357 CNC cylinder heads.
Brodix HV Intake
MSD Digital 6 Ignition
JLSTOEC 12-26-2007 11:07 AM
Oh yeah, The Brodix HV is the intake I have for it but I would be willing to change. Any suggestions on that would be helpful as well.
hammertime 12-26-2007 11:15 AM
1050 is what I'd put on it, for the best GAS carbs check out either a APD or a Pro Systems.
OneBadGMC 12-26-2007 11:27 AM
http://www.timmcamis.com/cool_stuff.html
There's a carb calculator on McAmis' site.
adjones419 12-27-2007 09:25 AM
1050 Quick Fuel Dominator
lanham 12-27-2007 02:54 PM
carb
If you are buying an out of the box carb then go with a Holley Dominator 1150 cfm,but for the price go with Pro Systems and they will recommend what you need.
scuncio 12-27-2007 06:29 PM
Look into Dale Cubic @ CFM carbs, He makes a real nice carb.
Tod74 12-27-2007 07:50 PM
I have a 540 similar to yours with smaller heads than you have in a 3050 lb car with a 8896 1050 and it works great.
JLSTOEC 12-28-2007 07:58 AM
Thanks for the responses.. I have a 1250 dominator and have heard it is too big. How much power/ET do you sacrifice running a carb that is too big? Also, what intakes do you guys like for a BBC making 825 HP?
lanham 12-28-2007 02:37 PM
carb
I like a super victor intake.Call pro sytems and ask if the 1250 is too big.A buddy of mine just got a pro systems carb and they recommended a 1200cfm for his motor and it is a 540.He had a 1050 quickfuel and put the pro systems carb on and picked up about a half a tenth.
