fuel pump rod for roller
I have a GMPP crate motor.It's a Fastburn 385.It's got a steel roller cam in it.It came with a distributor that had the bronze gear on it,my question is about the fuel pump rod for the mechanical fuel pump.Does it need to be made of a certain material(bronze?)so as to not wear out something.I can find no info anywhere,and the "tech"at the dealership I bought the engine from,didn't know what a bronze gear was.
Rod
I would also put a Bronze Tipped Fuel-Pump Pushrod in the Motor!You can get them at just about any HP Outlet?I buy alot of Parts from Comp Products in Oshkosh Wi.
Hope this Helps? Later G 8) |
Cool.Thanks for info
| All times are GMT -8. The time now is 03:48 AM. |
