-   -   327 with aluminum heads (https://www.racingjunk.com/forums/showthread.php?t=19316)
west68 12-27-2007 04:24 PM
wondering what a 327 with flat top pistons an 57cc aluminum head with 194 valves heads are 86 corvette heads L98 what the compression ratio would be an what would be a good head gasket to use thanks rw
amal 12-29-2007 06:30 AM
CR will be around 9.8:1 with 0.04" head gasket.
caprice327 12-31-2007 09:13 AM
http://www.wallaceracing.com/cr_test2.php
This calculator is worthless! Dont use it
burgessdg 01-01-2008 01:23 PM
compression ratio
Just looking at the numbers, I think you are both a litttle off. Looks to be more like 10 to 10.5-1. Here is another calculator. To be accurate you have to know the CC's of the reliefs and the Deck height. .040" is a good assumption for the gasket you should be using (standard permatorque).
Dan
http://www.wheelspin.net/calc/calc2.html
caprice327 01-02-2008 08:49 AM
http://store.summitracing.com/partde...2&autoview=sku
http://www.amazon.com/Permatex-80697.../dp/B000HBNUDQ
With that set you can have piece of mind that youl never have to deal with a blown head gasket.
CR with above gasket is 13.31:1 with one calculator and 11:1 with the other now when I check both calculators to a factory 8.5:1 motor the calculator I posted is wrong and should be hacked off the internet.
According to the wheelspin.net calc you would be @ 11:1 with the above gasket set.
jmarksdragster 01-02-2008 01:59 PM
Fel Pro 1003.
