Would like to run alcohol carb instead of Injection
I was thinking about running an alcohol carb this year. I was wondering will I still gain the power from a carb instead of running the ron or a hilborn style. I know injection is always better. I always thought you could drop about .2 to .25 from your et. by running alcohol injection. I'm just starting out with this. I figure I would start with a carb it may be a little cheaper.
Injection is usually close to a tenth faster, I've did the swap both ways a few times. www.apdracing.com Give these guys a call for great alky carb.
Re: Would like to run alcohol carb instead of Injection
If you have a single carb manifold, get a Ron's unit. If you have a tunnel ram, go with an Enderle. If you don't have a manifold and like the Nostalgia look, get the stacks. |
Motor in the car it's a 1998 camaro, it's not the easiest to do a intake swap. I have a 1150 worked I was just going to have it switched over. It should be about 500 or so. I've been keeping up with you guys post about alky I'm going to try it out this season. I figured I would loose about a .10.
I dont see over a tenth from a rons toilet to a carb, atleast both properly setup. Get someone good to do the change over on the carb if not you'll fight it ! Seem it way to many times.
i had an apd & a Rupert carb,both work well,my personnal preferance is Rupert,i just bought another one.
Thanks for the info.
Carbs
I got a Rupert Gas carb and love it. If I was going to alcohol, which I have thought about it would not be Rupert....it would be APD. What would one expect to see in e.t gain going to alky on a 496 BBC in a dragster? Car runs around 5.10 (5.06 best with me)with a best e.t. of 4.96 with a smaller driver. What do you think?
I thought Rupert stirctly did Alky Carbs??? I have owned nothing but Rupert carbs and after watching others struggle with their APD, I would hesitate to own it unless it came directly off of Randy's car.
As for injection to a carb, when we took the hat injection off our dragster it went from 7.80's to 7.90's. It was .15-.20 difference. The response and torque off injection is far greater than a single carb. |
| All times are GMT -8. The time now is 07:26 AM. |
