-   -   Brad Penn oil (https://www.racingjunk.com/forums/showthread.php?t=19458)
lanham 01-08-2008 04:10 PM
Brad Penn oil
Just wondering how much have you guys been giving for sae 50 Brad Penn racing oil.
obsessedtruck 01-08-2008 04:33 PM
35$ a case for 20-50. At the shop 50w is the same price that we sell.
davis419b 01-08-2008 04:44 PM
$36 a case for 50wt and its worth every penny!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
edvancedengines 01-08-2008 08:40 PM
A friend of mine, Watt Bigem that is an engine builder and has a nice machine shop in Lavon Teaxs named Watt's Shop is a Master WD for the Brad Penn Oils. I know he stocks a good diverse supply and will give you fair pricing.
I do not know his pricing but his phone number is
972-853-2647
If you need to email instead the email addy is
[email protected]
Ed
hink 01-09-2008 05:09 AM
We have found out that the Brad Penn oils they have lower zinc and phosephate for some reason and we have used this oil for cam break in for years with no probems and we also used the old Rotella T 15/40 before they lowed the zinc in that oil. In fact if you call Brad Penn thay won't even tell you the zinc content.
Now we have gone to the http://www.cen-pe-co.com/ as they have a 15/40 for the older deisel engines that has 1582 ppm of zinc and over 1300 phosephate and they 20/50 oil is higher in both zinc and phosephate.
cepx111 01-09-2008 07:38 PM
I seen some new castrol oil the other day at the parts store which is suppose to be loaded with all the anti wear stuff, not sure of the zinc content but its a 15w 40 designed for heavy duty trucks and machinery. Anybody have the low down on this new castrol oil? ><Cp
lanham 01-11-2008 04:38 PM
oil
I was wanting to see what the oil was going for.I can sell the Brad Penn oil for $35 a case but i would have to buy a little quanity and don't know if there is enough people in my area to move enough of it.
russ67chevelle 05-17-2008 10:24 AM
my engine builder says basically its good stuff(brad penn 20-50) and very resistant to breaking down from contaminents...any comments?
also someone above said it has low zddp when on their web site it says 1200 or higher ppm. am i missing something???
please help
hink 05-17-2008 11:57 AM
please help
The http://www.cen-pe-co.com/ 20/50 has 2300 PPM of zinc and is high in phosephate and since the Brad Penn lowered there zinc we Had to get away from it.
We have used the 50 weight http://www.cen-pe-co.com/ in our alky blower engines we build and no problems.
upstand 05-17-2008 06:13 PM
What about 20w50 motorccle oil? It is supposed to still be loaded with zinc. I think I'm going to try it. I mean if it's good enough for a 12,000 rpm bike it's good enough for a 7000 rpm sbc. Seems to have better anti shearing capabilities. Pick any brand and the car or bike 50wt are the same price but the bike oil has zinc and phospherous.
