power valves on dominators
from experience guys im asking what are the effects of useing the power valves on the primary side of a 1150 dominator or not? i see quick fuel offers ther new 1150 gas model with them and i see other well know poeple not. my set up is 565ci and i leave on a trans brake. just curious which way would be the first choice. thanks for all imput in advance
With, makes it a little less rich in the pits.
Yep, what Mark said. If you're one of those people who can't resist firing it up at home to annoy the neighbors, scare the dog, wow your buddies, or just for a good nose hit to pacify you till the weekend, you might consider power valves. The plugs will stay a lot cleaner under those conditions. Jet down about 6 steps when installing the pv. As far as any performace advantage, zip, zero, nada......
| All times are GMT -8. The time now is 12:43 PM. |
