-   -   Where Can I Find A BBC to SBC Front Adapter Motor Plate. (https://www.racingjunk.com/forums/showthread.php?t=19495)
dragraceme 01-13-2008 02:17 AM
Like The One In The Picture See Ad #1080656
johnracer 01-13-2008 03:35 AM
You'll probably have to get one made for you. I fabricated spacers to go between the rear of the big block tabs on the chassis and the front of a straight small block motor plate. Looked and worked fine. I can email you a pic or I'll post it here if someone can tell me how....
dragraceme 01-13-2008 03:43 AM
You can email me a pic. to [email protected]
johnracer 01-13-2008 04:31 AM
Email sent....
edvancedengines 01-13-2008 06:48 AM
Any sheet metal shop shoul;d be able to fab that up from scratch for you. It shouldn't be that big of a deal. Just tell them how much of a Z you need on it.
You can also buy a semi-finished SB Plate for a wider frame than you have and get the sheet metal shop to just make it to be offset like the one you want. You are just talking about 4 bends at a 45 deg angle. Then fit the rest to your car. It does look cool though.
Ed
gnsrule 01-13-2008 09:55 AM
This should set you up right:
http://www.quartermax.com/details.ph...1056&catID=192
jmarksdragster 01-13-2008 11:17 AM
Tommy makes the motor plates you need, as well other stuff like trans shields.
http://www.racecarpartsdepot.com/tra...n-shields.html
Racefab57 01-13-2008 07:33 PM
Suncoast racecars has em.David.
