-   -   Mastang Looses Belts (https://www.racingjunk.com/forums/showthread.php?t=19541)
bsahall 01-17-2008 10:26 AM
Any body got any ideas about how to keep an alternator belt on at 7500 rpm's? I have a 351 windsor in a Fox Mustang, running an electric drive on the water pump, no power steering or A/C. I need bracket ideas for the alternator to keep the belt from flying off. Thanks.[/i][/b]
fla1976 01-17-2008 04:09 PM
Alternator belt
You could try changing the alternator pulley to a larger diameter one. Check the belt for alignment.
bjuice 01-17-2008 04:16 PM
if you do not have the DEEP GROOVE race type pulleys you will continue to have the problem...also when you put on the DEEP GROOVE pulley make sure you get a COG belt the sits way down in the pulley groove..once the belt sits down in the groove you should see sides of the pulley coming up above the belt...this will 99% solve your problem.
Keep in mind stock type pulleys and stock fitting type belts were not designed for turning 7500 rpm's.
Brian
olds48 01-19-2008 12:09 AM
Run a belt that is as short as you can possibly run.Helps a lot
cepx111 01-19-2008 03:08 AM
I would recomend a serpetine belt set up, they tend to stay on with the higher rpms engines like yours. You can get a later model alternator and brackets from a donor car at a local bone yard. I also think jegs and summit is conversion kits too.
Goodluck
><Charles
