-   -   S-10 Rears (https://www.racingjunk.com/forums/showthread.php?t=19577)
Sox 01-21-2008 08:26 AM
S-10 Rears
Can anybody tell me what rears will work in a S-10.I just bought a S-10 with a 7.5 and would like to know if there is any rears that would work besides aftermarket ones. Thanks..
v8Fiero 01-21-2008 08:54 AM
what year do you have? I have an 01 ZR2 s10 blazer for a winter daily driver. the zr2s came with upgraded 3.73s, normal s10s are smaller, 3.10? you can also get chev 4.11 or 4.56 gears for pretty cheap compared to aftermarket axles.
us7race 01-21-2008 10:17 AM
I used run a 10-bolt from a mid 70's camaro using a 10" wide wheel and 7.5" of backspacing the wheels will stick out a little.. I have also heard that you can drop in an 8.8 out of an explorer basically the same width as a stock S10..
I am still running the same rearend in the truck pictured below just had it narrowed 6 3/4" with the same wheels..15x10 with 7.5" BS
Sox 01-21-2008 11:39 AM
S-10
The truck is a 87 with a stock width rear. 15x7 rims and a 275-60 tire. i dont know the back spacing.I dont want to back half it .Just looking for a rear maybe a 8.5 10 bolt that would fit. Im new to this S-10 stuff.Thanks..
us7race 01-21-2008 12:41 PM
Yea that is the rear I run. But like I said the tires would stick out a little,even with alot of backspacing.
sds10racer 01-21-2008 08:28 PM
in my '88 s10 i have early '70's bronco rear. it measures 58" oveall. you can run up to 6.5 back spacing and still not hit the frame.
lookingaround 01-23-2008 12:53 PM
alot of the 80's model s10 had factory 410 gears. you can get one out of a explorer it is a 8.8 2 inches wider inch on each side but no biggie. it would hold up alot better then the stock 7.5.
CHEVYMATT 01-27-2008 03:42 AM
axle
all the zr2 s10 trucks and blazers carry the 8.5 10bolt with 31 spline axles .not the 7.5. the width is a perfect fit just need to concentrate on offset.
