rod weight comparison--aluminum vs steel
what would be total rod weight for a 6.7 length grp aluminum rod with standard bbc wrist pin and crank pin sizes compared to an oliver or crower billet steel rod of same size?
don't know the answer off the top..but a home page check of the rod you have in question will give you the gram weight of each rod..along with more info.
Brian |
| All times are GMT -8. The time now is 07:34 AM. |
