rebuild roller rockers
Anyone know of a company that rebuilds sbc roller rockers?
Re: rebuild roller rockers
I purchased from Summit,which are Summit brand
Sorry to say, but those are probably going to be disposables.
You could try a local tool and die shop. You could also probably do it yourself. Assuming the bearings are just a press fit, with a "C" clip retainer on either side of the shaft. http://www.bocabearings.com/ Pull the bearing out and mic it. Boca has some high grade stuff that I'm sure would work, and would probably be better quality than what it came with. |
Thanks for the info
| All times are GMT -8. The time now is 10:17 AM. |
