-   -   just wandering what you guys think (https://www.racingjunk.com/forums/showthread.php?t=19614)
kw89425 01-23-2008 04:08 PM
i have a 69 nova back half ladder bar car 9" with 4:88's 31x14 tire's. go will go between 2800 and 2900 lbs. glide with brake and 5500 stall. the motor is a 496 eagle rotating with je pistons final is around 10.25 or so comp. all roller 300 306 hyd. roller lift is 6 somethingi cant find the card. heads are cast oval port that have been heavily massaged strip dominater intake with an hp 950 on it. 6al 2 step msd dist. headers are 2" 3.5". give me some input and oppinions as to what you guys think it may run..
mcracecars 01-23-2008 05:38 PM
should be no problem mid to low 10s, maybe high nines..... personally for that size motor, I would go at least 2 1/8 headers with 4" collectors....
kw89425 01-23-2008 05:42 PM
i would like to have a set. i will have to save some money all that i have looked at are pretty pricey
