Need help on BBC heads
I have a set of heads cast #6272990 one is cracked.i am going to a big swap meet Sunday in Nashville TN. and i would like to find a head that will match my good one.What other numbers would work and look the same outside?Please help ASAP!
you may want to take a look at a 14096188.
http://www.gmpartsdirect.com/perform...CATID=361.html
There's a chart at the bottom that should help you identify all the common GM heads (made by GM). |
| All times are GMT -8. The time now is 07:55 AM. |
