What's your altered weigh?
I'm trying to figure out what my car will end up weighing.
It's a 150 inch Bantam. We will probably put a iron head bbc in it. |
One buddy has a 23T with a sbc in it he is around 150-165lbs its 1800 with him in it.
if you dont have scales to weigh the car, take it to a truck stop , unload your car and drive it on the scale and pay the charge
Thanks guys for the responses. |
I seen one on the scales last yr. with a rat, that weighed 1630 no driver, so 1800lbs sounds realistic.
Zip. |
Mine weighs 1,650lbs without me in it. Sbc w/alum. heads,2-spd,small rad under the front,all fluids and 3 gallons of methanol and crome moly chassis.
Our fed weighs 1400 with an aluminum headed small block and rad, no driver.
Thanks guys.
We were guessing 1800-2000. |
1500lbs w/bbc......2050lbs with a 150lb driver with a set of 400lb balls to drive it.... :shock:
[img]http://i210.photobucket.com/albums/b...n/altered2.jpg[/img] |
| All times are GMT -8. The time now is 11:54 AM. |
