-   -   WHAT HEAD GASKETS (https://www.racingjunk.com/forums/showthread.php?t=19751)
lmchevy 02-04-2008 03:44 PM
WHAT HEAD GASKETS
On a 15.1 BBC would the regular Fel-Pro head gaskets be ok or would i need the Fel-Pro MLS gaskets.The bore size is 4.560 and the regular Fel-Pro gasket # is 1057.This is a N/A motor.Thanks
bjuice 02-04-2008 04:02 PM
i have a 14:1 Cr motor and i run the Fel-Pro- Cometic head gaskets with head studs..the study i did on them before i dropped $200 on a set of head gaskets came out good..there were claims of turbo,Nos,Blower guys running these gaskets with high cylinder pressure and not squeeing one out..so i went with them..happy so far....
i would stud the heads if you haven't already for more squeeze.
My take on it..
Brian
fla1976 02-04-2008 05:50 PM
Head gasket
I would highly recommend the Cometic gaskets. A local engine builder of super gas engines got me to use them after a head gasket blowout and I never had the problem again. I also went with a head stud kit. A few extra dollars but well worth the peace of mind.
