Ethanol fuel??
I've heard of guys running a 50/50 mixture of ethanol and 91 octane pump gas in their cars. Anyone out there tried it? I guess its suppost to be like the M85 gas. I was told you can run your normal gas carb and jet up 3 sizes. This is suppost to give an extra tenth. :? [/u]
got a circle track friend that runs a 500 holley 2bbl and mixes it 60 % e85 and says it run better and cooler. when it's 100 out side and you're running around in circles for 20 laps he says no heating problems even when you are under yellow. he only had to go up 1 size to get the plugs to color right. he tried 2 and was a little too rich.
But what compression doe they run? And does it combust diferent than say C14?
Re: Ethanol fuel??
check these websites 02-technology.com e85fuel.com classicmtrsprts.com quickfueltechnology.com |
the ethanol will eat the foam in your fuel cell, youll need braided lines but it doesnt dirty up the carb as much as race fuel, finally high octane low price its kinda like a whole nother wal-mart all in its self
E85
When running more ethenol you need to change your carb, ethenol is very close to the same as alcohol.
In most cases we see people loose more power than they make due to incorrect fuel curvs. |
| All times are GMT -8. The time now is 12:02 AM. |
