-   -   How do i remove the lower a arms in a 83 camaro (https://www.racingjunk.com/forums/showthread.php?t=19772)
triplexdogg08 02-07-2008 04:53 AM
I think i want to change my motor mounts and the best way i see of doing this is to remove the lower a arms and go through the spring pocket to get to the back bolts on the mounts, also i want to change the bushings to the hodchkis ones, i guess i was wondering if i could do this in my garage at home or do i need some special set up, worried about the spring tension. thx to all
signsbyesa 02-07-2008 05:49 AM
i used spring tension supressors and you can also use a floor
jack after popping the tierod out, and you will need a press
to get the new bushings in the arms, i had a brake shop do the
bushing for 10 bucks for upper and lower, polyurathane with
a little grease, carefule with the springs, gearheads have
been killed from the springs, good luck :?
triplexdogg08 02-08-2008 09:38 AM
well i got the springs out and i am still alive lol, what do you guys think about dropping the k member out while i have it tore down this far, and maybe even putting a spohn tubular k member in it what do ya think
signsbyesa 02-08-2008 04:48 PM
upgrading for more torque is always a good thing :lol:
