2speed pg
The class im going to run in i cant have electronics delay box etc. is the 2 step module and my trans brake ran through the delay box? Also I went from a small block to BBC and my drive line comes in to tranny at a 5 degree angle is that going to work.
More then likely your 2 step wire is connected to your transbrake terminal on your delay box its pretty easy to bypass this for no box though.
trans brake
What would i run that wire to just possitive feed?
| All times are GMT -8. The time now is 03:13 AM. |
