-   -   tempermental 700r4 (https://www.racingjunk.com/forums/showthread.php?t=19823)
hughesis21 02-11-2008 12:43 AM
tempermental 700r4
i have a 1990 camaro 350 tpi 700r4, 4.10 posi
when i take off like normal " like old people" it shifts firm and what seems to be on time, when i shift it manually through the gears it shifts hard enough to chirp the tires, but when i put it in drive it takes forever for it to shift. going from 2 to 3 it feels like it runs out of useable rpms then shifts and feels like i kicked the nos on. whats the problem????
olds48 02-11-2008 07:52 PM
Does that model have a governer?If it was a TH350 or 400 I'd say that was it.
SST4530 02-11-2008 08:18 PM
Sounds like the TV or (throttle valve) is sticking. There used to be a cable that went from the throttle body or carb to the transmission. This cable controls a valve that works against the govenor pressure to determine when the trans shifts. TV gets it's pressure from the line pressure of the trans, the more throttle the more the TV opens to prevent the govenor pressure from shifting the valve. This cable can be adjusted to control the shift points. The govenor could also be sticking or be bad. :)
olds48 02-12-2008 06:19 AM
WOW! :shock: Blittle kinda-sorta agreed with me!I feel smart! :P
jmarksdragster 02-12-2008 11:47 AM
Most 700R4 issues stem from the TV area, either sticking valve or more likely misadjusted cable. It is very important to get it right as this controls line pressure as well. If someone has installed a shift kit, it further complicates things. Some work fine, some not so well. It is best to find an experienced performance trans shop to help get it under control. This isn't always easy either....
hughesis21 02-13-2008 07:45 PM
i have tried adjusting the tv cable it didnt make no difference, i am going to put a new filter and fluid in it, is there any fluid i need to stay away from or any i need to get?? i do not know any thing about 700r4 trannys
lively 02-13-2008 08:03 PM
BLITTLE PROBABLY HAD A HICCUP AT THAT TIME :lol: :lol: :lol: ---LIVELY
olds48 02-14-2008 12:50 PM
SST4530 02-14-2008 04:57 PM
Awww now, when a flella's on track, he's on track!
:wink:
SST4530 02-14-2008 05:00 PM
If adjusting the cable made no differeance then it probably is the throttle valve or circiut. If you don't know anything about it I would have it checked by a good trans shop. Those are few and far between though!
