what oil for alcohol?
Whats the best oil to use with 700hp alcohol engine,
I use VR1 Valvoline Racing Oil I thought about switching to Brad Penn but have had great luck with this oil.
Any synthetic oil, We use Royal Purple XPR 10W40 Racing oil in 90% of our engines using alcohol.
We have been doing a bunch of reading on the Joe Gibs racing oil, supposed to be the best on the market. |
oil
hey thanks does this help with milky oil and what weight should i use a 50 weight to help thicken oil that takes some alcohol in it?
drive line angle
My drive line has about 5 degree angle coming into my tranny and good pinion angle is this to much angle to tranny.
Not sure on the pinion angle, I am not a driveline or chassis specialist.
As for the oil, we run 10w 40 and 10w30 |
Most times oil gets milky with alcohol is becuase tune is too rich.
Old Fashioned if you can find it C I -4 Grade 15-40 Fleet or Diesel oils work very well for anything except blown. Blown you need heavier oils. In Chevrom RPM Dello it is called MUlti-Grade. Avoid the LE or Low Emmision. Shell Totella T if you can still find the CI-4 classification oil. Careful Shell is printing the CJ-4 to look like CI-4. The difference is that the J is combining with the C at the bottom but at the top is separeted. I found this with a magnigying glass after buying a buch of oil and it jsut didn't look right on the API symbol. NAPA also has good Fleet Oils. Remember it has to specify as API CI-4. Ed |
oil
thanks for the help. :lol:
Brad Penn.......Brad Penn.......Brad Penn !!!!!!!!!
Yeah what he said!!!!!!!! |
| All times are GMT -8. The time now is 06:08 AM. |
