drive line to trany angle
what the best angle from tranny to driveline angle? mine looks like 5 degrees is that to much?
1st off is it a ladder bar or 4 link ?
where are you taking your measurement from ? i would say 5 degree of pinion is too much on any drive line.. 4 links can get away with 1 degree up to 2-2.5 ( max).. ( less is better) i cannot make anymore comments about your set up until you tell us more . Brian |
tranny to drive line
My camaro is a 4 link, i just got the car and it was all ready set up, they took out the small block and put a BB in it with motor and mid plate the back of the engine looks like its going down hill, then when you look under the car that reflects onto the driveline to tranny angle, the pinion angle looks pretty good, but i dont know how to check one.
| All times are GMT -8. The time now is 02:02 AM. |
