Protecting sand blasted intake????
My aluminum was looking bad, so I sand blasted it with aluminum oxide blast media. It look great right now ,but I know the finish will get dull. I was going to use a walnut shell media next to see how good it l looked. Does anyone have an idea on how to protect the finish on this intake? I have used a clear polurethane from Eastwood, but I did not like the results after a couple of months. Maybe power coating is the answer.
Thanks Tony |
Powder coat it !!!I did and it always looks good!!!!!!!!!!! David
send it to Nitro Plate and get it coated !
i would say intakes are made from 6061 t6 alloy, so if there is a process where it can be plated, that,s your best bet, or powder coating, otherwise be prepared to do a lot of buffing, and blasting.
I had mine done as well as the timing cover in an aluminum powdercoat for my Buick. Still looks like brand new. Total cost from my guy for both pieces...$85 bucks!
[imghttp://i196.photobucket.com/albums/a...OTORMedium.jpg][/img] |
i paint my single carb intakes Black...MY Taste i guess.
No one has yet mentioned this, but I would be much more concerned about what the blasting did inside the manifold. Sand blasting an intake manifold can be very bad. No matter how hard yopu clean the media or sanding particles will be imbedded in and will get into your engine.
The outside is easy. Powder coat. Polish and clear coat. Paint with engine paint. Ed |
My powdercoater guy placed bungs into all holes to keep the blasting media out of it. He has some sort of pliable rubbery stuff that presses into the holes then expands to keep the media out. None was in the intake when he was finished and even then after several minutes and times being blown out,did anything come out. He is really particular in his ways. I realize not everyone is like him so you need to keep an eye on your powdercoater guy.
I agree that black and chrome look awsome but it wouldnt be so cool if you loose ET because of it... |
| All times are GMT -8. The time now is 02:11 AM. |
