-   -   Torque for aluminum heads (https://www.racingjunk.com/forums/showthread.php?t=19898)
bowtie4542001 02-19-2008 05:04 AM
Hey guys,
I just got a set of aluminum bowtie heads and need to know the torque specs. Also would it be beneficial to add head studs and coper head gaskets while I have the engine apart. Thanks in advance.
Chris
Tod74 02-19-2008 06:30 AM
I torqued my old big block GM ALUM heads to 75 ftlbs. The new Brodix I just got had a paper with them that said to torque them to 70 ftlbs.
zipper06 02-19-2008 07:18 PM
What Tod said, but i perfer the copper gaskets because you can use them over and over again, you didn't say if it's s/blk or b/blk. I always stud a s/bk but the last motor i built 476" b/blk 2 milk crate motor we used Felpro and ARP head bolts. Not my choice but the owner did not want to spend the money.
Tod74 02-20-2008 04:50 AM
ZIP when you head stud one do you just finger tight or do you lock a couple nuts together and lightly snug them?
bowtie4542001 02-20-2008 05:48 AM
Its a s/blk. Sorry for not stating it to start with.
dcarr511 02-20-2008 08:52 AM
I'm not Zip .. but you want them to just be snugged up, not tight, ARP comes with the ends broached for an allen wrench.
Studs are great when on a Dragster ... but try taking a cyl. head off of the engine in most any door car. no fun at all. I'm ' returning " to bolts in my cars ....
bjuice 02-20-2008 03:56 PM
Cris- Duane brought up a good point about taking off the heads while in the door car with head studs..it could be a challange..to the point of having to yank out motor or at least pull forward..
if ya wanting the extra sealing power around the cylinder then i would check into the FEL-PRO MLS head gasket's..about $200 for the set and use head bolts the closest thing to o-ringing a block without doing it.
( i have a little un-fair advantage of your situation then most people cause the motor use to be mine)
so i know your motor pretty good LOL...unless your gonna spray the thing or convert it to a blower motor and pack the cylinders i would not sweat the head studs etc....the copper gaskets are great as zip said for re-use but my opinion on this is Copper head gaskets are a great match for a o-ringed block,head studs and of course a good dose of Hylomar..
can you use one without the other...YES!...but its like swimming with your clothes on...lol :roll:
the motor has ran for 8 years with Regular Fel-pro head gaskets and head bolts at 13 to 1 compression..
just my take on it.
Brian
bowtie4542001 02-20-2008 06:01 PM
just my take on it.
Brian
Gottcha Brian, I am going to use Fel Pro with head bolts. I can't wait to hear that thing purrrr again.
Chris
zipper06 02-20-2008 09:53 PM
When i head stud one i put the head on with the gaskets in place, i then screw the studs in with blue lock tight until i have 3/16" above the lock nut with washer. I then remove the head and apply some sealer around the water openings on the gasket and re-assembly the heads and torque them in stages of 20lbs until i am at their required torque specs. I also retorque the heads after they have been fired up and allowed to run too temperature. It's been a long time since i have lost a gasket seal, with gas,alcohol, or blown alcohol. I know it's extra time, but it's cheaper than replacing and a lot of comfort when you need to make the next round.
edvancedengines 02-21-2008 02:13 AM
Torque 65 ft lbs to a max of 70 ft lbs. Head studs or bolts too tight will do more harm than good.
Small head 6 point ARP Bolts with washers. Head gasket of your choice.
For those who asked;
You do not want a stud installed in a block tight. I usually screw down by hand and back off by 1/4 turn and use a copper base anti-sieze on the threads lightly.
Ed
