-   -   need 2 grind my rockers down to make my valve covers fit (https://www.racingjunk.com/forums/showthread.php?t=19914)
xp537 02-20-2008 04:06 PM
I bought a set of powder coated big block valve covers they look like the ones that come with the chevy 572 crate motors but they say chevrolet on them but when I went to install them they hit one of the roller rockers where the indention is in the valve cover for the socket to bolt the cover down so I called the guy that I got them from and he said that is a problem with the big crane gold roller rockers and to just grind the corner of the rocker down a little so it fits and it will be ok . so I just want to make sure that it will be alright .
thanks LES
MileHighMan 02-20-2008 04:35 PM
xp. I don't have a part # for you but I used a very thick gasket from felpro. Is like over a 1/4in thick. Cleared stud girdle and all. Really saved my a$$. Good Luck. Dan.
itsabird 02-20-2008 06:17 PM
there are thicker gasket, but if you are not able to find any, you can always double the gasket, just glue them together.
zipper06 02-20-2008 07:24 PM
5/16" thk valve cover gaskets available from lots of sources. I sell them with cork/steel center. But i donot sell on RJ, contact Ron Owens he should have them in stock.
edvancedengines 02-21-2008 02:21 AM
Alo B&B/Stef's sells a valve cover spacer which can move it up too. Nothig wrong with stacking same valve cover gaskets and rtv them together.
Ed
xp537 02-21-2008 02:51 AM
this will have to be spaced up about a 1 1/2 or 2 inches so it will not touch it doesent hit the top of the cover it hits the side thanks for the replies
Pwmax 02-21-2008 03:34 AM
Just grind the rockers. Its usualy 2 per side. Its no big deal, and will not hurt the rocker. Some of the cranes now that I have seen lately, have that built in now.
Frank
Advanced Performance
www.get-ap.com
Tod74 02-21-2008 05:17 AM
Frank
www.get-ap.com
YES the new Crane Gold rockers have an angle on them to clear.
xp537 02-22-2008 03:32 PM
ok thanks guys I think I will just grind the rocker arm
