A/F ratios
How lean can one go and still not get into detanation in a N/A engine on methanol? For instance in my sbc 406 about 4.75/1 is as lean as i have tried. I still get quite a bit of oil dilution, so i assume I am still pretty rich, but I am afraid to go much leaner for fear of burning a hole in a piston. does anyone know if I can go, say 5/1 or maybe a little more 5.25/1 and still be safe, and maybe solve some of the dilution or at least cut back on it some.
I don't really know about a/f ratios, but, if it were mine. I'd tune it to run the best and quit worrying about it...
4.75/1 was its best E.T. and speed to date, and I would like to try it leaner, but I am worried about burning my engine down. However, I still appreciate your input, thanks.
JMO Zip. |
Don't be afraid to lean it out. You'd have to go really, REALLY lean to hurt it unless you're running nitrous or some sort of forced induction with a lot of boost....
Another thought, if you're injected, the oil delution could be the barrel valve adjustment, or running the engine too cold w/carb or injection...
Like ZIP said you need an EGT.
Where can I get an EGT?
| All times are GMT -8. The time now is 01:33 AM. |
