-   -   advice on driveshaft (https://www.racingjunk.com/forums/showthread.php?t=20019)
olds48 02-29-2008 09:33 PM
I recently tubbed my car.Everything is squared away except my driveshaft.I have yokes on both ends(trans and rearend)that are 1350s.The driveshaft I have been running is out of a 74 Nove w/250 6cyl.Not sure what the ujoints are on the driveshaft,they measure 3 1/4' wide and have 1 1/16" diameter caps.Been running crossover ujoints(at least that's what I call 'em).Real question is,my pipe is only 2 1/2" in diameter.Do I need to step it up?Like I said,I just tubbed it,but am not making any extra power as of yet.Had no problems before.Money is tight and was wondering how much power it would safely handle.Estimated my power to be 600hp,don't really know.Car is about 3300 lbs with me in it and have run a best of 6.90 at 99 mph in the 1/8.Any help very much appreciated.
lively 03-01-2008 05:17 AM
ONE OF THOSE BIG RUBBER BANDS FROM WALLY WORLD WILL WORK!!!!!!!! JUST MAKE SURE YOU STAPLE IT TO THE YOKES REAL GOOD :lol: :lol: :lol: :lol:
olds48 03-01-2008 05:33 AM
:lol: :lol: :lol:
lively 03-01-2008 08:27 AM
JUST THINK---ONCE IT WINDS UP TIGHT ONE WAY IT WILL RECOIL THE OTHER WAY--REAL FAST IN THE WRONG DIRECTION :lol: :lol: :lol: ]---LIVELY
bryanm 03-04-2008 02:24 PM
Tube diameter is not nearly as important as wall thickness. My driveshaft is only 2.5 inch diameter but it is .095 wall, as long as you have .083 wall it should be fine.
olds48 03-04-2008 03:17 PM
Hmm...wonder what mine is? :?
bjuice 03-04-2008 03:59 PM
if you are gonna run it on the street i would not worry about what you have...its not going to hook good enough on the street the compromise the shaft...if you take it to the strip with slicks etc...you need to upgrade your shaft..i would say minimum of .083 wall 3 inch tube..
again as long as your not dead hooking,,you will have not much to worry about.. IMO.
if you have a chassis cert guy near you he can sonic check the wall thickness and tell you.
Brian
sg1586 03-04-2008 06:19 PM
Get a new one from this guy...You will be happy and they have great service too......
http://www.dennysdriveshaft.com/
olds48 03-04-2008 07:41 PM
Brian
It won't be on the street any except for my own personal Sunday after church test and tune :D The neighbors love it. But what do you mean exactly about dead hooking?
bjuice 03-05-2008 04:31 PM
SORRY..LOl..its just a figure of speech..remember i am an old east coast southern boy..
all it means is to hook hard off the line,(slicks,VHT)..."No Wheel Spin"...when this happens as you may know its transferring all the energy to the ring gear.axles,drive shaft u-joints,yoke etc...
when you hook that thing "dead hook"...you can take it to the bank its gonna find the weak spot in your drive line..
it normally raises its ugly head somewhere between the axles and drive shaft,u-joint.. 1st...
Nothing to take lightly..
Brian
