-   -   Rear End Size for 72 Nova (https://www.racingjunk.com/forums/showthread.php?t=20026)
davebat 03-01-2008 01:31 PM
I need to get a posi unit for my 72 Nova, but I don't want to have to change the case. It has 10 bolt on the rear pan, is that an 8.5 or 7.5? And can I get an auburn unit kit for it?
Help?
sp2816 03-01-2008 06:53 PM
Nova rear end
That would be neither the 7.5" or the 8.5". It would be the 8.2" diameter ring and pinion.
I am not sure about the Auburn units, though.
Bill Mitchell
signsbyesa 03-01-2008 09:54 PM
my nova was a 10 bolt 8.5" ring went with auburn pro-series
28 spline posi, takes all my 383 will give, with kick a$$ axels
from www.tomsdiferentials.com
davebat 03-02-2008 03:32 AM
That's not a good website address, but thanks. There is a crate rearend place on the web I'll search for (currie I think).
Hoping that I can use the case for a 8.5 posi unit. How can I tell?
Tod74 03-02-2008 04:33 AM
http://www.tomsdifferentials.com/
http://www.tomsdifferentials.com/tomp.htm
he had the right address he just mispelled it. Happens to everyone now and then. :D
signsbyesa 03-02-2008 05:09 PM
thanx for the correction tod, i will blame the computer ha.
tom's has all you need to change a 10 bolt in to a heavy
monster. the good rebuildable 10 bolts have ears on the bottom,
if they don't go with a 12 bolt if you have to replace it, i am
going to have my 10 bolt for sale in a month, going with
a shorten rear with a spool the 10 bolt has 3:73 US gears
good luck :wink:
