Help from the TH-350 experts!
Correct me if I'm wrong. And please don't respond if you have a guess. Please be pretty sure to positive
No matter what size tailshaft a TH-350 has the trans mount is always in the same place. was there a Th-350 ever made that has a different case where the trans mount would be moved about 2-4 inches back so that it would be in the same place as a 700-r4. Meaning a 700-r4 X-member would be universal with this particular Th-350???? Thanks |
No the mount on the 350 is on the case and there are no other 350 cases the only car that a 350 fit where a 700 was is a corvette 84-96 and that req a spacer and the tailhousing from the 700
| All times are GMT -8. The time now is 03:17 PM. |
