What kind of timing
What kind of timing should I run on a 482bbc 13.5-1,aluminum headed motor with a 720 roller?I was thinking around 36* plus or minus 2*.And I don't have the cam card for the cam so what is the ideal lash setting for a solid roller 720 lift cam?Someone told to start with .026 straight across and go from there.
Gas -39-40
Alky 36-37 |
I ran 42 degrees total advance on my old big block and it loved it.
I ran a 496 w/ 40 deg. total and a 714 solid roller.. best was 24 int / 22 exh..
| All times are GMT -8. The time now is 11:00 PM. |
