-   -   J&J Diapers (https://www.racingjunk.com/forums/showthread.php?t=20045)
hammertime 03-02-2008 07:04 PM
J&J Diapers
Just installed my first J&J Diaper today. Fits nice and was pretty easy to install. Got mine from Jegs Thumbs up to J&J ! :) :!:
tyster 03-03-2008 04:40 AM
Post up a pic David. My stroud is getting a little old. Is J&J the brand that Ric Wallin sells?
3dracing 03-03-2008 06:12 AM
Yes it is.
Steve
hammertime 03-03-2008 09:22 AM
Yep Ty same diaper, $215.00 from Jegs though. I will take some pics tonight when I am home.
tyster 03-03-2008 02:14 PM
Whenever you get a chance David, if I decide not to go with the Stroud again I'll get one from him, he's a fellow S/Q racer. :D
hammertime 03-03-2008 06:38 PM
Side View of Diaper
Plenty of strap to pull tight and fit
http://i203.photobucket.com/albums/a...b/100_1469.jpg
One of the front straps
http://i203.photobucket.com/albums/a...b/100_1470.jpg
Other side against header
http://i203.photobucket.com/albums/a...b/100_1471.jpg
Around oil pan
http://i203.photobucket.com/albums/a...b/100_1473.jpg
Back Strap to hold it
http://i203.photobucket.com/albums/a...b/100_1465.jpg
jmtire 03-04-2008 06:18 PM
diaper
think I'll make a pan with some oil dri pads. How would you replace a starter fast? Looks like the mounting anchors could knock a plug wire off, but only in the finals!!! just my thoughts
hammertime 03-04-2008 07:07 PM
Re: diaper
Simple enough 3 header bolts on each side and 4 clips and the diaper is off. The mount tabs do not hit the plug wires once you tighten them.
The diaper is a good idea for people not wanting to screw up powdercoating, if you have a painted chassis the belly pan would be the way to go. But just isnt the case for most of us.
hammertime 03-10-2008 09:35 AM
http://i203.photobucket.com/albums/a...b/100_1488.jpg
Here is the picture of it to show the room between the plug wire and diaper.
