heads & piston
hi guys just woundering if anyone has done this exercize .
i have a 414 sbc with 23deg heads , im thinking of changing to a set of 15deg or 12deg . can i get away with yousing the same piston its a JE with an 11cc dome ? cheers chris |
Yes you can.
The valve notches on the pistons will need to be compltely redone though. Ed |
Originally Posted by edvancedengines
Yes you can.
| All times are GMT -8. The time now is 02:34 AM. |
