-   -   load testing 16 v battery (https://www.racingjunk.com/forums/showthread.php?t=20098)
deepockets 03-05-2008 05:07 PM
any know if i can use a 12 volt load tester om my 16 volt batterie, if so what numbers should i expect to see? good numbers vs bad numbers. i just neet to know so i wont be troubleing the batterie place. thanks
oneowner73 03-18-2008 05:31 PM
Tried it on my battery with the battery load tester from work and still dont know the numbers. But I do know that I almost melted down the tester.
