-   -   worth anything? (https://www.racingjunk.com/forums/showthread.php?t=20105)
mopar1968 03-05-2008 07:32 PM
worth anything?
I took 2 set's of big block chevy heads in on trade for parts, the man needed the parts i had so i gave in, the casting number is 3856213, they are 427 heads, very good condition, closed chambers, didn't measure but seems to have large valves, as some of you know i am a die hard mopar man so i don't need these, anyone have any idea what these might be worth?
Tod74 03-07-2008 04:44 AM
Re: worth anything?
Oh I disagree!! A Big Block Chevy is E X A C T L Y what that Mopar needs. :D jk
As far as I know...those are not off of a 427. (could be wrong though)
Those heads are closed chamber ,oval port ,truck heads....off of a 366. They were used 66-70. Unless they have been worked on they have 2.06/ 1.72 valves. BBC "big valves" were 2.19 /1.88
Not worth anything much I wouldn't think...but I am no head guy.
mopar1968 03-07-2008 07:46 AM
worth
I didn't know about them never ran a chevy, i didn't need the intake or camshaft and his car wasn't running, so just trying to help out. scrap yard i guess.
Tod74 03-07-2008 08:17 AM
I don't know if they are a casting that is worth working on or not...someone will know I'm sure. I know there are some "peanut port" truck castings that can be ported into a good street head...but don't know which casting numbers those were. Ed would probably know I'm sure.
iceman454 03-07-2008 01:23 PM
i think you can get $200
mopar1968 03-07-2008 06:42 PM
heads
I have two sets if i could get $100.00 per set they are gone.
topsportsman1 03-07-2008 07:02 PM
3856213....66-82...oval..CLOSED..366T, 427T
PartyTimeRacing 03-16-2008 04:52 PM
To put your heads in perspective, I damaged a couple of chambers in a pair of (far superior) 454 LS-6 heads and they were easliy fixable but weren't worth fixing. There are just too many great aftermarket heads available for those motors now. Even the best iron closed-chamber heads are now boat anchors.
mopar1968 03-16-2008 05:39 PM
heads
That's about what i thought, like i said i am a mopar man myself, just helping out someone with parts for his car. thanks for the info.
