-   -   N.O.S. help (https://www.racingjunk.com/forums/showthread.php?t=20106)
bigray 03-05-2008 07:45 PM
N.O.S. help
we have a alcohol motor.if you put nos to it.can you inject alcohol or does it need to be gas and nos ????
tyster 03-06-2008 04:29 AM
I run Alky and enrich with race fuel but Speedtech, NX and others sells kits where you can enrich with Akly. Bob Payton can help ya if he sees this as he enriches with Alky
image4you2see 03-06-2008 04:40 AM
Most guys run a seperate fuel system with race gas in it for the N2O..
bigray 03-06-2008 03:58 PM
thanks for the input.thats what i thought.but wanted some advice.thanks
racecrafter 03-07-2008 04:03 AM
If you are using a "small" shot Alky will not be a problem as you increase the quantity the temp of the intake mixture can go low enough that fuel atomization can become a problem...I can be more specific if you give a little more info about your setup and how much you nitrous you wish to add.
bigray 03-08-2008 10:05 PM
well as strange as it may sound we are putting it on a jr dragter.i was also looking at putting a dry set up on it. and just bumping up in main fuel jet size.the set up is from dyne tune.for a 4 stroke quad with a 9hp or 15hp shot.just wanting a little more out of it.and like always go FASTER.
olds48 03-13-2008 07:35 PM
A junior dragster on alcohol and nitrous??!!Gutsy kid (dad?):D
