-   -   s10 blazer front springs (https://www.racingjunk.com/forums/showthread.php?t=20136)
sgblazer2 03-07-2008 07:06 PM
i have a 89 s10 blazer, 383, the truck has a 2/2 drop, traction bars, and with 28/12.5/15 tires on rear. The problem is the truck is walking around on the track and i think it may be because its sitting low in the front(weight distribution problem). Is there any drag springs for the s10's or should I just go back to stock?
olds48 03-08-2008 04:45 AM
How's your caster?I've found that when you lift a truck,if you roll the caster the slightest bit,on accident,it can make HUGE differences in handling.Wander if yours might have gotten affected when you lowered yours?
Tod74 03-08-2008 08:28 AM
MORE CASTER THE BETTER...for going straight, anyway.
