Header Question on a 632
I have a 72 Chevelle ansd am putting together a 632 10- 1/2 to 1
motor. with the tall deck what headers do I need will hooker Super Comp work or do I need special Headers. |
Headers
What heads are you running on the engine? With the T/D and any head with a raised exh. port you are going to have some problems. If the front stub has been done you have a better chance of getting some to fit.
But be ready to change a few tubes, it may be your only hope. Super Comps. in my Nova 540 T/D .400 raised exh. port We changed 4 tubes, and the front stub was done. Plated, crossmember cut, and a rack. You can try Kooks, or Lemons they may have something that might work? But they will cost almost as much as a fabbed set will run you. Good Luck |
| All times are GMT -8. The time now is 02:55 AM. |
