aftermarket main caps-383
At what point should you consider using aftermarket main caps for a 550-600 h.p. 383 sbc?
at the point when you start pooring money in the motor
and don't want it spitting out a rod, a small block throwing 600 hspwr, get the equipment made to take the torque 8) |
Look and see what GM rates a stock cap at in there catolog and go from there.
Here are some links to look over http://www.nastyz28.com/forum/showth...731#post264731 http://www.chevelles.com/forums/showthread.php?t=38173 |
Thanks Carl
| All times are GMT -8. The time now is 11:05 AM. |
