-   -   Can You Make A Dominator 1050 Work On The Street ? (https://www.racingjunk.com/forums/showthread.php?t=20206)
71duster 03-13-2008 06:41 PM
I have a 340 W5 heads,roller cam 715,718 lift,11.5cr.
727 trans,4800 stall,513 gear.
thanks
olds48 03-13-2008 07:23 PM
Ran one on the street for a little while.496 BBC 11:1 comp 652 solid roller with 308 duration and a 4000 stall.4.88 gears.Worked fine. Just another carb,if you ask me.As long as it's not too big for your engine(which I don't think it is),should be fine :D
zerotolerance 03-14-2008 06:33 AM
there not bad to work with on the street i would deffinetly recomend running a power valve in the front to help clean up the primarys. we run 4500s here on the street with out any problems we also use the three circut dominator that way you can play with the mid cicrut and air bleeds. hope this helps
olds48 03-14-2008 01:32 PM
YES!Powervalves are a must for the street!!
dcarr511 03-14-2008 04:18 PM
Re: Can You Make A Dominator 1050 Work On The Street ?
thanks
absolutly you can. and as mentioned a PV up front is a must and in the rear also might help out. They can be made to work in the secondairies
jmarksdragster 03-14-2008 04:48 PM
If you are buying, buy the 8082 2-circuit, not the 3. Much easier to tune correctly.
dcarr511 03-15-2008 11:05 AM
That would be a good idea, and saves a step in " fixing " it.
71duster 03-22-2008 03:16 PM
I have a old one so I'll have to find some place to send it to.
Any recomendations on were to send too ?
Thanks for the help.
