-   -   Lifter bore problem (https://www.racingjunk.com/forums/showthread.php?t=20232)
altune 03-15-2008 09:45 PM
Lifter bore problem
I need to find out how much lifter bore clearance is acceptable. I had some issues with low oil pressure in a race engine of mine and one of the lifters got a bit stuck in the lifter hole. I had to use a pry bar to remove it and it looked scorched.
I dont want to throw the block away but may have to.
any easy fix for these?
Al
hink 03-16-2008 05:31 AM
Re: Lifter bore problem
Al
What engine are you talking about and what lifters ???
altune 03-16-2008 02:35 PM
block is sbc 509 casting.
lifters are solid roller, crower I think.
Al
hink 03-17-2008 08:41 AM
Al
The lifter bores in that block can be bushed back to standard bore or they can be machined to .875 and no bushings or even .904.
