-   -   Line Locks (https://www.racingjunk.com/forums/showthread.php?t=20255)
face 03-17-2008 11:10 AM
Line Locks
I have line locks installed on Vega. They don't hold very well.. Any advice on the best way to install them ? How the lines should run.
Thanks
itsabird 03-17-2008 11:51 AM
will it hold any at all?
fla1976 03-17-2008 12:26 PM
Line locks
I had trouble with the front brakes holding on my Vega when I installed a line lock. I built a low pressure bleeder and bled the brakes again and it worked fine. It is hard to get all the air out with just pumping and bleeding. The low pressure bleed doesn't compress the air in the line and allows it to be purged.
mcracecars 03-17-2008 04:31 PM
could be air in the line... or wired backwards if the tires are turning.
skinny fronts tires with big rear tire cars, can push the front tires through the beams when stalled against the converter....
topcat572 03-17-2008 05:52 PM
lock
Its been a while, but I used a stage gauge {pressure} and pumped the brakes while holding the button down. The gauge lets You know whats happening on the brake side. :lol:
sc3314 04-09-2008 07:26 AM
Brakes
Just try pumping the brakes a few times to get the line pressure up. Then set the line lock this may help. Or pressure bleed the system to make sure the air is out.
Do you have a pressure valve installed on the rear brakes?
Racefab57 04-15-2008 08:28 AM
Pressure bleeding is the best but if you dont have one just take your time bleeding DONT PUMP PEDAL RAPIDLY just pump them slowly then open bleeder, I do it with a vac pump hooked to the farthest bleeder away from the master,then next farthest away,and so on working slowly and it works great! David,good luck.
olds48 04-27-2008 03:34 PM
It's not wired backwards.You're dealing with DC not AC voltage.Polarity doesn't matter on a DC solenoid,and that's all a line lock is.Just like an electric fan for a radiator.Wanna mount it on the other side and reverse it.Reverse the polarity and it'll turn the other way.As long as the blades are pitched to be reversible.You're wiring is fine :D
Pdmracing 06-18-2008 09:31 AM
I have the same problem on my monza, when i pulled the pads last nite they were glazed like glass, I replaced 7 turned rotors, ill let you know if it works this weekend.
