-   -   blow by (https://www.racingjunk.com/forums/showthread.php?t=20263)
arobunson 03-17-2008 05:31 PM
blow by
i have a sbc 408 with lot of blow back pressure, motor is kind of new just been together for 3 months lot of white smoke coming from breather cap what could this be thanks
bjuice 03-17-2008 05:51 PM
Its oil getting past your rings..some HP Race motors are built loose and could possible have some minor blow by....thats why a vaccum pump is highly recommended/required..
if you do not have $600.00 to invest in a vaccum pump..at least install some e-vac tubes in the headers
hard to tell by internet how bad your blow-by is...so i am just making a general statement here..
but its oil getting thru
Brian
zipper06 03-17-2008 07:55 PM
White smoke may indicate a water leak, being it's a 400 blk. they are notorious for blown head gaskets. Have you noticed any milking of the oil?
arobunson 03-18-2008 12:26 AM
no water in oil thanks
hink 03-18-2008 04:45 AM
400 blocks if they are not plate honed with the same hardware it will show alot of blow by and if your building a lot of cylinder pressure its even worse.
Do a leak down test.
arobunson 03-21-2008 07:31 PM
ok compression check #1-190, #3-135,#5-0, #7-230, #2-220, #4-225, #6-220, #8-230 could it be rings or head problem
hink 03-21-2008 08:20 PM
You really need to do a leak down test!!!!!!!!
cepx111 03-21-2008 10:01 PM
Take the head off on the drivers side, the problem should be quite evident since you have "ZERO" compression on number 5 cylinder.
My money has it that you have a hole in the top of your piston.
Goodluck, Charles
hink 03-22-2008 04:28 AM
You maybe looking at a bent valve!!!!!!
suicidebomb 03-22-2008 07:04 AM
re; blowby
I once forgot to install the #5 piston, but I knew right off, somthing was amiss, rod made a terrible clatter.
