350 sbc ring problem???????
I am installing a new set of rings, standard bore, only thing different is that the cylinders was honed. I have used 2 different set of rings and the oil rings are to tight to fit in the bores. piston goes right in with comp rings. I also cleaned ring grooves with no luck. Any Ideas?
Did you check the oil ring end gap? the rails may be butting.Bill
ring gap
yes approx .025 oil ring gap
Make sure you have the correct radial thickness ring for your piston, in other words the ring could be thicker than the groove is deep.
problem solved
in 87-88 they made a shallow groove pisto and the standard deep groove we have the shallow groove. Thanks for your input
| All times are GMT -8. The time now is 03:33 AM. |
