-   -   how big of bore gen 5 bbc (https://www.racingjunk.com/forums/showthread.php?t=20280)
randybryan 03-18-2008 06:24 PM
I have a bbc marine, gen 5, 4 bolt block. Going to freshen. Thinking about a new rotating assembly. How big can you bore this block and still be reliable. It's a bracket/index motor. Dont want to fill block.
68bbnova 03-18-2008 07:36 PM
454 or 502?
OneBadGMC 03-18-2008 09:11 PM
If you're worried about reliability, don't go more than .060 over. Put a 4-1/4" crank in it and be done.
hink 03-19-2008 03:31 AM
A soinic test would be the way to go!!!!!!
randybryan 03-21-2008 07:42 PM
454
it is a 454 block
cepx111 03-21-2008 10:48 PM
DITTO!
TopspeedLowet 04-04-2008 10:03 AM
Re: how big of bore gen 5 bbc
I have been using a bow tie gen v block bored to 4.600 using 15 to one comp. and have no grout in the block. The GM max recomended bore for this block is 4.6". Grout is for bone stock blocks with core shift. A new aftermarket block is cheep insurance for block quality. You'll have more in machine work and gimicks to get the durability of a good block than a good block costs. You decide
