ARP OIL PUMP STUD?
On a sbc what should I torque a arp oil pump stud at?
Check very carefully or this one will bite you, if you are using a stock block, make sure the stud does NOT extend into the bearing especially on a 400, don't ask how I found out. :cry: Aftermarket blocks should be OK.[/list]
| All times are GMT -8. The time now is 07:48 PM. |
