-   -   Possible frame flex (https://www.racingjunk.com/forums/showthread.php?t=20301)
SPEEDNEEDS1 03-21-2008 10:02 AM
Possible frame flex
I have a 66 Chevelle, Aluminum head BBC and when I raise it up in the air, I can measure from back of valve cover to the firewall and it moves about 1/8 of a inch. Solid motor and trans. mounts with 2 bars running from cage to front frame. What can be moving?????? and what do I do to fix it????? It does have stock front frame.
itsabird 03-21-2008 10:29 AM
the only thing i can think of, is body mount bushing, if you now have rubber, you may want to try plastic.
itsabird 03-21-2008 01:25 PM
sorry about that, ment solid alum.
