-   -   Rookie Help - Kickdown/PassingGear Linkage? (https://www.racingjunk.com/forums/showthread.php?t=20320)
BD74SS 03-23-2008 05:41 AM
Can some explain what the Kickdown/PassingGear Linkage, is? Do I need to even hook it up? I've got 2 (short track) enduros cars, one with a 2bbl the other 4bbl. Both have th350 trannys. Thanks for the help.
jmarksdragster 03-23-2008 11:36 AM
The kickdown cable on a TH350 is only for full throttle kickdown. Part throttle is controlled by the vacuum modulator. It's OK to disconnect it.
BD74SS 03-23-2008 11:54 AM
Is there a advantage. Hooked or unhooked
Is there a advantage either way? Reason asking both cables are broke. Im runing both cars in drive, around the track. 2nd just has the stock motors screaming. Our top speed is around 55-60.
