-   -   Picking a new intake for 454 BBC (https://www.racingjunk.com/forums/showthread.php?t=20337)
hettman 03-24-2008 11:37 AM
I'm doing some work to my 454 BBC just bought a set of good oval port heads and a new cam. I'm trying to figure out what type of intake to run. I've talked to some people and they say victor jr, is this a god intake?
hammertime 03-24-2008 11:43 AM
dont get a team g ...
victor intakes are good intakes
hettman 03-24-2008 11:55 AM
what is the difference between victor and victor jr?
topcat572 03-24-2008 01:12 PM
victors
The victor has a dominator flange, the jr, dont. :wink:
hettman 03-24-2008 01:31 PM
thank you, for explaining the difference , so would you recommend the victor jr.
Tod74 03-24-2008 02:13 PM
Re: victors
I thought a 454-R or a 454-O was a "Victor Junior" ? if so You can buy a Victor Junior with a Dominator flange or 4150 flange... :?
edit:
I just looked at mine...it is a 454-R and it says "Victor Jr." on it and 454-R....The 454-R is available with a 4500 flange or the 4150 Flange. It is a great intake in my opinion. I have had two of them.
p.s. 454-O is the same exact intake as 454-R just has oval ports rather than rect. The meat is there if you wanted to open it up later on...I had a 454-O with my old motor and rather than port it I sold it and bought the 454-R
bjuice 03-24-2008 02:40 PM
i run a 454-r..but i did run a team "g"..the newer team "g"s are better then the older ones...but if i had to buy one i would go with the 454-r.
if you want a worked team "g" dominater flange...i have one you can buy cheap...just pm me..
oh yeah my motor ( 511 ci) ran a 5.99 at 114mph @ 3,000 lbs with this team "g'.....don't know what the 454-r will pick it up ( on gas with same carb) but will find out soon.
Brian
topcat572 03-24-2008 04:53 PM
manifold
You are correct, the 454-r and 454-o are the same dominator intake with different ports. These are listed as Victors in the catalog. The only oval port Victor Jr. listed is with a 4150 carburetor. May be they more than is listed or things may have changed since Your intake was made. Man, this is confusing. :shock:
Tod74 03-24-2008 10:51 PM
Re: manifold
Yep..you are right...My 4150 flanged one has "Victor Jr." embossed on it..but I just saw a 454-R with a Dominator flange on ebay and it only says "Victor"
jrthone 03-25-2008 01:37 AM
Ive only ever heard good things about victor Jnr manifolds and every one is running them and making very good power out of them.
