-   -   1.6 to 1 rockers under stock valve covers??? (https://www.racingjunk.com/forums/showthread.php?t=20364)
hughesis21 03-26-2008 06:47 PM
i have a 97 vortech 350, i know that the stock pushrods are weak and i am wanting to put 1.6 rockers in it. i am told by a local "crooked" machine shop that i will have to buy tall valve covers. theres a problem with that. i have put this motor in a 97 s10 everything done right i used the factory wireharness its still fuel injected just rewrote the cpu. its all factory lookin i even have my air cond. i do not believe i can put tall valve covers in there. i have to take fenders off just to change plugs!
johnracer 03-26-2008 07:27 PM
They should clear stock valve covers. The real issue is the hole in the head that the pushrod comes up through. A 1.6 rocker has the pushrod seat relocated closer to the stud to change the ratio. The hole in the head may have to be elongated to gain the necessary clearance.....
mopar1968 03-26-2008 08:27 PM
rockers
If it helps you i have a small block mopar and i have 1.7 roller rockers on it.
sds10racer 03-26-2008 09:02 PM
what johnracer said. i've got the same set up in my pu and the guy that put the engine together before me didn't open up the push rod guides. there was a little wear on the push rods. i opened em up when i had the heads off last year. the only time i think you'll need the tall covers is when you put a girdle on.
cbtlr 03-26-2008 09:43 PM
Are we talking non roller 1.6's or rollers?I just went to full rollers on a sbc with no girdle and had to get spacers for covers.I'm not a engine guru.But I did have my exp with full rollers and valve cover clearance.
sds10racer 03-27-2008 08:32 PM
mine are crane gold self aligning 1.6.
